salm82
Feb 14, 2020Initiate
router keeps rebooting itself
hi. ever since the new firmware update, my router keeps rebooting itself or my connection pauses for a few minutes until i switch the router off/on. i know it's the router because when i try to get i...
- Feb 14, 2020
Yes you can go back to old firmware. Folks suggest the .42 version.
Go here to get the firmware and a user guide. Put in your router model.
https://www.netgear.com/support/download/default.aspx
On the firmware down load selection click on the purple icon on lower right. That will display the older versions. Read in the user guide how to do a manual install of the firmware using an Ethernet attached PC/MAC rather then doing over wireless. The manual method is the only one that is pretty much going to install firmware without issue.
labatt
Feb 14, 2020Mentor
salm82
thank you. :)
