Ewillhelm
Oct 29, 2021Aspirant
Router kicks everyone off every time a new device joins
So yeah, every time a device joins our wifi network, it causes all currently-connected devices, as well as the one trying to join, to be kicked off the internet. This lasts a few minutes, and then co...
Oct 29, 2021Guru - Experienced User
Does it happen with both wired and wireless?
Does the Internet LED on top of the router change color when this happens?
Does the modem in router with with wifi running and the R7000P turned OFF exhibit same thing if you connect everything to the ISP modem?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor enabled?
Ewillhelm
No.
No.
Don't know.
I'll try this.
There are, but again, I noticed this only happens when a device (like a laptop) that's accessed our network before tries to access it again, as in after you first turn it on.
Is Armor enabled?
It WAS for an accidental trial period, but now it's off again.
No.
- FURRYe38Oct 29, 2021Guru - Experienced User
Try a factory reset and setup from scratch at some point.
