Ewillhelm
Oct 29, 2021Aspirant
Router kicks everyone off every time a new device joins
So yeah, every time a device joins our wifi network, it causes all currently-connected devices, as well as the one trying to join, to be kicked off the internet. This lasts a few minutes, and then co...
Oct 29, 2021Guru - Experienced User
So turning the att's wifi off doesn't put it in passthrough. and I've seen posts with that gateway not functioning properly in passthrough mode. Its not the greatest coded ISP supplied device I've seen.
Have you tried simply leaving it in router mode, disable its wifi, and run the netgear in access point mode?
Ewillhelm
Man, this is what I hate about multiple devices. I remember going through all this initially, and my current setup was what the Netgear folks said I needed to do (Netgear in router mode etc). I fear I'll just screw everything up more if I start making changes, but oh well.
- FURRYe38Oct 29, 2021Guru - Experienced User
I recommend the reset and setup from scratch then also set up the router as plemans mentioned in AP mode with the ISP modem. Just ensure the modems wifi radios are disabled. Disable IP pass-thru as well. It's not needed if the router is in AP mode. https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
