Aiyubb7
Aug 01, 2021Aspirant
Router light blinking green
I factory reset and have tried manually installing the download firmware. But I have a chromebook and not a windows laptop, therefore the softwares aren’t compatible. Is there anyway for me to do this...
antinode
Aug 01, 2021Guru
> [...] have tried manually installing the download firmware. [...]
"tried" _how_, exactly? What, exactly, did you download? What,
exactly, did you do with it? Did you read the instructions in the
Release Notes which are provided with the firmware image file?
> [...] I have a chromebook and not a windows laptop, therefore the
> softwares aren't compatible. [...]
_What_ "the softwares"?
> [...] Is there anyway for me to do this on a chromebook?
Have you a web browser on your (unspecified) "a chromebook"?
Did you consider trying this radical concept (which works for some
people):
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Update the Firmware". Further reading might not hurt, either.
- Aiyubb7Aug 01, 2021AspirantI’m not going to take abuse from a virgin like you. Can smell you all the way here
- antinodeAug 01, 2021Guru
> I'm not going to take abuse [...]
Nor advice, apparently. You're welcome.
https://en.wikipedia.org/wiki/Dunning%E2%80%93Kruger_effect
"[...] therefore the softwares aren't compatible.""But I wore the lemon juice."
