Aiyubb7
Aug 01, 2021Aspirant
Router light blinking green
I factory reset and have tried manually installing the download firmware. But I have a chromebook and not a windows laptop, therefore the softwares aren’t compatible. Is there anyway for me to do this...
antinode
Aug 01, 2021Guru
> [...] have tried manually installing the download firmware. [...]
"tried" _how_, exactly? What, exactly, did you download? What,
exactly, did you do with it? Did you read the instructions in the
Release Notes which are provided with the firmware image file?
> [...] I have a chromebook and not a windows laptop, therefore the
> softwares aren't compatible. [...]
_What_ "the softwares"?
> [...] Is there anyway for me to do this on a chromebook?
Have you a web browser on your (unspecified) "a chromebook"?
Did you consider trying this radical concept (which works for some
people):
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Update the Firmware". Further reading might not hurt, either.
Aiyubb7
I’m not going to take abuse from a virgin like you. Can smell you all the way here
- antinodeAug 01, 2021Guru
> I'm not going to take abuse [...]
Nor advice, apparently. You're welcome.
https://en.wikipedia.org/wiki/Dunning%E2%80%93Kruger_effect
"[...] therefore the softwares aren't compatible.""But I wore the lemon juice."
