PlayaGal
Apr 22, 2019Tutor
Router Log-in
Hi, All of my devices but one seem to be on the 2.4gh band. Consequently the connection to the Roku stick is not great. I am trying to log into the router to change to Smart Choice so it will autom...
Apr 22, 2019Guru - Experienced User
Are you logging in via app or via a browser? Try via the browser. Also try not to use autofill. Just in case that's causing the problem.
If you're accessing it via the browser, you can hit cancel, enter your serial number and then you'll have to answer the security questions you setup. Provided you do that, it should give you the password. If you don't remember your password, you might need to reset it.
Default login: admin
default password: password
PlayaGal
Apr 22, 2019Tutor
Thank you for the fast reply Plemans!
I was trying through the safari browser on my iPhone. I may have initially connected all using a PC. I am sorry to ask this but would I have created a (router log in) UserID and Password at some point during set up? I don’t recall doing that. In all honesty connecting new and old devices to the router my head is swimming with log on credentials and I don’t see where I wrote this down.
Thank you very kindly!
