PlayaGal
Apr 22, 2019Tutor
Router Log-in
Hi, All of my devices but one seem to be on the 2.4gh band. Consequently the connection to the Roku stick is not great. I am trying to log into the router to change to Smart Choice so it will autom...
schumaku
Apr 22, 2019Guru - Experienced User
Reads to me like a problem with the 5 GHz reach in your environment... SmartConnect won't help much.
PlayaGal
Apr 22, 2019Tutor
Thanks for the reply Schumaku (Sensei).
I just don’t know. The first few days only one iPhone was on the 2.4gh band and everything else on the 5gh. Now it’s the opposite. I figured that the router was choosing the best band for each device even though the slide is off (in the Nighthawk app) for Smart Connect. As I mentioned in a prior post, when I moved the slide to “on” I lost device connection to the router and had to start over. So, I thought I would try it through routerlogin. I thought I was going to love the router and in fact it works much better than our 10 year old Netgear. But without this community there is not a lot of help for new users or infrequent users. What concerns me is that the Roku box is 8 feet from the router yet I am getting only a “good” signal strength and that was after raising the router 10 inches higher onto another table. One of the reasons we got a new Router was all the buffering and stopping on DirecTV and Roku.
I am aware that our DTV receiver is known for issues but their solution is to charge for a new one. So far better reception than before but I have no idea how I would know if the router is working properly, is faulty or other issues are going on. It’s discouraging. Sorry to whine! Thanks so much for all your help!
- IrvSpApr 22, 2019Master
Some of what you say makes no sense to me?
First, Smart Connect, and what is does when set. With it on, ALL SSID's share the SAME SSID and PASSWORD. You MANUALLY connect to that ONE SSID. The router 'supposedly' knows enough to put the proper devices on the proper band. Unfortunately, that is in theory. NG's implementation seems to be a 'load leveling' method. That means it will try to keep the same number of devices on each SSID. It is not a 'switching' implementation either, that it would dynamically load level. Once on a band, the device stays there.
In theory, all the devices the senses is faster will go to the 5Ghz band, and the slower to the 2.4Ghz band, until the number on the bands are uneven than it doesn't care, a device will be put on the band with the least devices.
That is what I discovered on the R8000 and so did SMALL BUILDERS NET that reviewed that router. More than likely all NG routers act like this.
Now you said Smart Connect was off. With that being true, it can get 'dicey'.
You have to MANAULLY connect to an SSID the first time. If you had previously connected to both SSID's, that is where you can run into the devices being not on a band you want. Especially mobile devices vs. a desktop PC on a desk. The reason being the device usually will connect to the STRONGEST SSID signal. This means it might depend on where it was turned on and if it moved to the outer range of the SSID signals. The 2.4Ghz signal will generally travel farther than the 5Ghz. However, towards the outer limits of the SSID's, the 5Ghz will be stronger but not as far reaching as the 2.4Ghz SSID. Once on an SSID devices will usually stay there until it sees the signal to weak to use and will switch when it finds a stronger signal.
Basically Smart Connect will not solve this.
Best way to keep the devices on the specific bands you want. On each device you have determine which SSID you want to be on. Then on that device FORGET the other SSID. That will fix it, again, assuming the 5Ghz band is working properly. Note, house construction can change the strength of the signals, and the 2.4Ghz band is more likely to have interference weaking the signal as well.
- PlayaGalApr 23, 2019TutorThank you for the reply and helpful information IrvSP. It does not surprise me that what I posted doesn’t make sense. This is way more than I expected to have to do to set up a new router and connect everything. Now posters are discussing corrupt firmware updates. Our previous NETGEAR Router seemed so much less trouble. Or maybe we just didn’t know about or understand these issues. It too was a dual band however only one SSID or choice showed when we were connecting printers or phones or other wireless devices. This Router appears as Netgear07 and 5g. Or at least it sometimes does. My husband connected to 5g with his iPhone. Not knowing 5g was also our router I selected Netgear07 which apparently is the name/choice for the 2.4gh band. Setting up the Router I didn’t realize the bands could or should have two SSID so they both use the same SSID and password. There was not a good explanation in the start up guide of what Smart Connect is. Looking at it on the NIGHTHAWK app I can see it is not turned on. When I did turn it on My devices lost their connection, I got errors saying the router could not be found. I ended up rebooting the modem and router and reconnecting devices one at a time as I originally did. This is when I noticed I could not connect my phone to 5g. Since then most times when I check to see what is connected to which band printers, DirecTV, my phone and now the Roku Stick are all using the 2.4gh band and my husbands phone is on 5g. Even when I disconnected my phone by “forgetting the network and then reconnecting to 5g when I letter checked connected devices through the Nighthawk App my phone was back on 2.4gh. Oddly enough running slows tests through the Nighthawk App the speeds reach 10-12mbps (we have DSL). If I check my iPhone while it’s connected to 2.4gh and use the ookla speed test it reaches about 1/2 that speed. Connected to 5g it reaches the same speeds as through the Nighthawk App. I am thinking about contacting our DSL provider to ask if our DSL supports 5g. I hope that makes more sense or is clearer. I apologize for any confusion, I am still learning. I appreciate everyone’s patience and kind assistance!
- IrvSpApr 23, 2019Master
I'm afraid you might still be confused and so am I?
PlayaGal wrote:
Our previous NETGEAR Router seemed so much less trouble. Or maybe we just didn’t know about or understand these issues. It too was a dual band however only one SSID or choice showed when we were connecting printers or phones or other wireless devices.Might help if you posted that model number? It seems that it would have to have had Smart Connect on to do what you are saying... without it on, you should see 2 distinct SSID's being broadcast.
PlayaGal wrote:
This Router appears as Netgear07 and 5g. Or at least it sometimes does. My husband connected to 5g with his iPhone. Not knowing 5g was also our router I selected Netgear07 which apparently is the name/choice for the 2.4gh band.Well, the actual DEFAULT SSID's are listed on the bottom label of the router. They should start with 'NETGEAR' and usually have a number after it. Even on the Dual bands only one SSID, the 2.4Ghz is shown. That is in case you can only connect via wireless. Once connected you go to the WIRELESS tab on a browse login to the GENIE GUI and you can then see the DEFAULT 5Ghz SSID and you CAN change either or both. If you turn on Smart Connect the 2.4Ghz SSID and password is the only one that will be broadcast.
PlayaGal wrote:
Looking at it on the NIGHTHAWK app I can see it is not turned on. When I did turn it on My devices lost their connection, I got errors saying the router could not be found. I ended up rebooting the modem and router and reconnecting devices one at a time as I originally did. This is when I noticed I could not connect my phone to 5g.Yes, this is probably correct. Switching to it from it off probably did disconnect you and you would need a reboot. By the way, using the NightHawk app to me is NOT the way to go. It has limited functions. Better way is to use a BROWSER and for the URL enter the IP Address (or ROUTERLOGIN.NET) to get to the 'real' Genie Graphical User Interface (GUI). There supply the same USERID and PASSWORD (default is admin and password unless you changed it during setup) and you'll have a lot more capabilities to manage the router.
PlayaGal wrote:
This is when I noticed I could not connect my phone to 5g. Since then most times when I check to see what is connected to which band printers, DirecTV, my phone and now the Roku Stick are all using the 2.4gh band and my husbands phone is on 5g.Point of confusion for me. At this point from what you posted it seems SMART CONNECT was enabled? If that is the case, the router 'decides' who connects to what? I'll assume your husband's phone is newer? Probably AC speed capable while your's might not be? Other than the phones, those are all generally 2.4Ghz devices, so it would be normal for the router to place them there. As I mentioned before, Smart Connect is not a DYNAMIC version but a LOAD LEVELING implementation. The actual band the device connects to might be depending on time connected and other devices already connected. It might also be that it was determined your phone would work better on the lower band, especially if it connected far from the router. The BEST way to do it, TURN OFF SMART CONNECT and then CUSTOMIZE the 2 SSID's to be UNIQUE and also identifies the band, like ROUTER2 and ROUTER5 for the 2 bands (2.4Ghz and 5Ghz) and then connect the devices to those SSID's as you see fit. Be aware, connecting a 2.4Ghz ONLY device, like a printer for instance, can and will slow down the 5Ghz SSID for ALL devices that connect to it.
PlayaGal wrote:
Oddly enough running slows tests through the Nighthawk App the speeds reach 10-12mbps (we have DSL). If I check my iPhone while it’s connected to 2.4gh and use the ookla speed test it reaches about 1/2 that speed. Connected to 5g it reaches the same speeds as through the Nighthawk App.That makes sense to me. The NightHawk app speed test done on the Router, not your phone. Any WIRELESS devices speed depends on many factors. One is what is the device RATED speed, today, usually N or AC, and that along with distance from router and the number of Antennea's the phone has determines speed. The 2.4Ghz SSID is good for at least 300Mbps. What is the DSL TRUE speed. DSL speed it the true number you should be getting on the ROUTER or via a WIRED CONNECTION. Now I don't understand why at 5Ghz connection the speed is faster? This could be a Firmware on the router issue.
PlayaGal wrote:
I am thinking about contacting our DSL provider to ask if our DSL supports 5g. I hope that makes more sense or is clearer.Don't bother doing that. The router is the one managing the WIRELESS (USUALLY unless you have a modem/router from your ISP, what model is it?) SSID's. However this sentence makes me think the ISP's modem is also wireless and active? If so, it could be a problem and interferring? You might also be connected to it wirelessly, hence the two different SSID's you've seen, NETGEAR07 (which I'm sure IS the router) and 5G which would be unless you altered the setting? Could be coming from the ISP modem/router? Really need the ISP modem model I guess to be sure (or how the signal get to the R7000P?
- PlayaGalApr 23, 2019TutorIrvSP- Thanks for the great explanation of what the Smart Connect button is supposed to do. I am not sure it does anything for my situation other than disconnect devices from the router. Incidentally I did not turn it off.
I followed the connection instructions through Netgear’s website, the QuickStart guide and the Nighthawk App but did not adjust or change anything that wasn’t addressed. Since then I have used that app to look at settings, devices connected, traffic etc. it was then that I saw the Smart Connect slider/button and noted it was off.
Thanks again for all your assistance!!!
Have a great morning! - PlayaGalApr 23, 2019TutorI just realized that my post had veered off the log-in topic. Sorry. I just want to clarify for those who were trying to assist, I have not yet logged-into the router. I will try from a pc (not my iPhone) later today. As for the Roku having only a “good” signal strength yet being located 6 ft from the router, previous posts have stated that Roku runs at 2.4gh so maybe this is the best we will do, if I am understanding that properly. Thank you all. I will check for replies when I get back this afternoon.
