PlayaGal's avatar
Apr 22, 2019
Router Log-in
Hi, All of my devices but one seem to be on the 2.4gh band. Consequently the connection to the Roku stick is not great. I am trying to log into the router to change to Smart Choice so it will autom...
  • schumaku's avatar
    schumaku
    Apr 23, 2019
    The best way is to enable Smart Connect, and let the technology work as it is supposed to do and to be.
    IrvSp any proof Smart Connect does load balancing targeting the same number of clients on each radio?
