NorthandSouth82
Apr 19, 2023Aspirant
Router login dot dev
Was trying to change Wi-Fi password. Came across routerlogin.dev Stupid me for clicking on the suspicious website and the moment I enter that site, my a/v informed me that it has blocked a connect...
Apr 19, 2023Guru - Experienced User
You might be fine with just a malware/antivirus scan.
but yes, a little on you for a random website. Whoops. It happens though.
Are you having issues?
