Acecon88's avatar
Acecon88
Follower
Apr 24, 2022
Router login issues
Accidentally changed the internet option to require login under the admin section for the router. Now I don't have internet and can't login. Any suggestions?
1 Reply
  • FURRYe38's avatar
    What router model are you referring too?
    You gave us nothing to go off.
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start wit
