Beekmans-online's avatar
Sep 29, 2016
Router login troubles R7000
I bought a second-hand Netgear R7000. When I tried to connect to this router via routerlogin.net it shows a site with the text "Detecting if there is an existing router in your network, please wait"....
  • Beekmans-online's avatar
    Sep 29, 2016
    My problem occur when I try to login via a Mac (mac OS Sierra).
    I tried a Windows PC and had no trouble logging in.
    Once I changed the IP-address, from the router, to a static one I could logging from my Mac too!!!
    So, every one thank you very much for thinking.
