ITMinion
Oct 18, 2022Star
Router Nighthawk X6 R8000, firmware V1.0.4.84 -web interface freezes
Hi all, I have confirmed that in V1.0.4.84, when editing any attached device (under Administration) to change its priority, after clicking on Apply, the web interface freezes up and the router must ...
- Oct 19, 2022
Ok so after enabling QoS,
I now see the Edit and same screen view on Attached Devices:
Selected Low priority and hit apply and got same hang on the browser:
Seems to crash the web page ui services. I still have internet access thru the router. I can ping the routers LAN IP address as well. Power cycling the router regains access to the routers web page.
I'll pass this on to NG.
Oct 18, 2022Guru - Experienced User
Had you tried this in a different browser to see if the problem follows?
What browser are you using?
Had a factory reset and setup from scratch been performed after you loaded v.84?
