feobrien
Dec 07, 2020Tutor
Router not assigning IP addresses after power outage
My router does not assign all IP addresses after power outage. Some devices get an IP address, others do not. It appears to me that hardwired devices are typically fine, the problem seems to be mainly with Wi-Fi connected devices. I solve the problem by a hard restart (unplug) the router. Sometimes this works on the first try, sometimes it takes two or three times before everything is back to normal. A soft restart of the router does not solve the problem. I see some solutions here that say to do a factory reset of the router, but that means setting everything up again. That seems like a very crude fix and hardly a solution to what appears to be a router firmware problem.
What router do you have?
Firwmare on it?
What modem/gateway is it connected to?
If you're having that frequent of power surges, I'd look into buying a cheap ups (backup power supply). Power surges are great at wrecking electronics and a ups is a cheap investment to protect your expensive equipment.
- feobrienTutor
Thanks. I have the R9000 running the latest firmware V1.0.5.24. I actually do have the router on a UPS. Unfortunately the other night the power was out for 2 hours.
it shouldn't take several days for devices to reconnect. Have you tried reinstalling the firmware or downgrading a version of the firmware? I know the r8000 had an issue for 1 firmware where it'd lose its settings after a reboot.
