Teg
Nov 20, 2016Aspirant
Router not connecting to network
1. Was running the R7000 with DSL until last week. Very easy set-up and worked like a champ. 2. Replaced DSL with uverse. 3. Connected the gateway to the router with an ethernet cable. Disabled w...
- Nov 22, 2016
I realized today that I had hardwired it to the computer but also was accessing it via wireless. There was a conflict. As soon as I disconnected the hard wire everything fell into place.
JamesGL
Nov 22, 2016NETGEAR Employee Retired
Hi Teg,
If you set the R7000 to AP mode, you have to access the UI using the IP address of the R7000 given by the main router.
JamesGL
Community Team
Teg
Nov 22, 2016Aspirant
- JamesGLNov 23, 2016NETGEAR Employee Retired
Hi Teg,
Thank you for the update. Good to know you found the fix.
JamesGL
Community Team
