Huston1976
Jun 18, 2021Aspirant
Router Not Giving Me 200 Mbps
I have fiber from a local cooperative. The Fiber runs to the house, into an ONT outside the house and then it comes into the house through a CAT cable. The cable goes directly into the router, there ...
- Jun 18, 2021
Nevermind, I found the issue: Turn off QoS.
Huston1976
michaelkenward
Jun 19, 2021Guru - Experienced User
Good idea. With 200 Mbps it isn't usually needed, and, as you have found, it can slow things down.
