Brandonkras's avatar
Aug 05, 2021
Router not receptive to potential speeds
In short, I am a gamer looking for optimal performances. I have 800mbps download speed through xfinity which was a recent upgrade. I have attempted all of the common fixes, restarts, factory reset, tr...
  • plemans's avatar
    Aug 06, 2021
    Try version 1.0.4.28 of the firmware. Install using a browser based method of install.
    If you have to, leave the modem disconnected during setup and skip the internet setup. Then it won't auto-update.
    Then you can disable the auto-update and connect the modem.
