stllkim
Nov 08, 2022Aspirant
Router not showing up as available networks
AC2300 Smart WiFi Router (R7000P) is not communicating to S22 Ultra nor S4 Tab. Not seeing NETGEAR33 5G as available network. I am seeing NETGEAR33_Ext. I don't recall seeing Ext before. Ext will not...
Nov 09, 2022Guru - Experienced User
Are you using smart connect? Smart connect combines the 2.4ghz and 5ghz network into a single ssid so they don't show as separate.
