Ryan15715
Jan 27, 2018Aspirant
Router Not working after having a other control panel than switching back to the regular
So i used to have a regular control panel routerlogin.net But Then I switched the firmware to dd-wrt Firmware But a month later I got to download the regular Netgear Firmware for my Model to...
- Jan 28, 2018
See previous answer. Talk to the people who know about DD-WRT.
antinode
Jan 27, 2018Guru
> [...] I got to download the regular Netgear Firmware for my Model to
> put the regular firmware back but then That's when The router Screwed
> up
Not a very detailed description of what you downloaded, or what you
did with it (whatever it was).
> [...] it said it has no IP anymore [...]
_What_ said what, exactly, when you did what, exactly?
> [...] I need Help
So do the non-psychics in your audience.
Ryan15715
Jan 28, 2018Aspirant
OK So a while back I switched to the DD-WRT Firmware but then i wanted to switch back and i did with the downloaded firmware from Netgear but then i screwed up my router and i said whenever i connect to it No IP and No internet access
- michaelkenwardJan 28, 2018Guru - Experienced User
