tgrstarr
Nov 09, 2017Aspirant
Router not working and have no idea what to do
- Nov 15, 2017
Hi tgrstarr,
The internet light is amber which means the router does not have internet connection. Connect your computer first to the modem and make sure it has internet connection. If it has internet connection, follow the KB below.
https://kb.netgear.com/1086/No-Internet-with-new-router-MAC-spoofing
tgrstarr
Phone shows WiFi connection. Tried rebooting router, phone and laptop.
clithes
Nov 09, 2017Prodigy
Are you using an Android phone? I've seen this before where the phone establishes a connection but you cannot access the internet.
Go onto wifi settings, select your wifi connection and choose 'forget network'. Then refresh and try to connect again. It will ask you for the wifi password again (as you've just deleted it), once you've put this in it usually connects and fixes the problem.
Hope this helps.
- tgrstarrNov 09, 2017AspirantPhone is iPhone 6s+. I will try when I get home from work. On the router, the one light is orange, where the others are white (see pic). Does this indicate anything?
- JamesGLNov 15, 2017NETGEAR Employee Retired
Hi tgrstarr,
- JamesGLNov 19, 2017NETGEAR Employee Retired
Hi tgrstarr,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
