Hart1951's avatar
Hart1951
Follower
Jun 21, 2021
Router not workinging with one of my client's VPN's
Have been using this router for about 18 months.  About 2 weeks ago, I was unable to access one of my client's VPN's.  After much troubleshooting, we determined the router was the problem.
Any suggestions on how to re-connect with the remote VPN after working fine for several months?  It works fine in all other aspects, but this one VPN is giving me problems.
1 Reply
  • plemans's avatar
    How did you determine the router was the problem?
    Did anything change in the last 2 weeks?
    Have you tried using a different dns provider like googles at 8.8.8.8 or 8.8.4.4  or even cloudfare at 1.1.1.1
    Also check your ipV4/6 settings.
