LindaLinda
Feb 25, 2022Follower
Router password changed itself
Hi, My router (which I've had for almost 2 years) changed its password on its own. Did I get hacked or do routers do that? I already changed the password for the router. Do I then need to change p...
Feb 26, 2022Guru - Experienced User
did it change back to the defaults?
sometimes that happens after a firmware upgrade.
If it wasn't to the defaults and you didn't change it, its always a good idea to change it to something else
