LucianoMM
Dec 24, 2021Aspirant
Router R6400V2 Reboot
I have a router R6400V2 nighhawk. Some time ago, I noticed that my internet connection was dropping. I found that my router was resetting too many times. I read a lot looking for the solution and ...
Dec 25, 2021Guru - Experienced User
A cheap laptop/usb fan might be an ideal solution before just drilling holes in it. I've seen a few people get enthusiastic with their drilling and hit the motherboard and wreck it. Plus the router has a usb port that can power the fan.
- plemansJan 02, 2022Guru - Experienced User
You're not going to get a response from netgear as this is the public support community.
If the device is still in warranty, you could check on an RMA.
Or use the fan option.
You might have just been anfortunate and gotten a device with a cpu the runs hot.
