Dracarus
May 26, 2021Initiate
Router R7000 keeps going offline
Router keeps going offline up to 4 times a day and it’s only 1 year old. I have updated the firmware, done multiple reboots to both router and modem. Any support out there or solutions that have worke...
mlap
Mmmm....
Strange, i have the same problem, started a few weeks ago.
but my router R7000 is 6 years old, so i didn't try much.
i'ts updatet an rebooted a few times,
and becouse it's 6 years old, i bougt new gear.
But iI am sure it's my router, not my modem.
Did you do a factory reset??
That's the next thing I'm going to try.
Bu don't know when i have time for it.
Today I have installed the new router, so my problem is solved ;-)
Try the factory reset if you didn't do it already.
mvg.
Mlap.
Dracarus
In my app I don’t see an option to do a factory reset. Are you referring to the reset button on the back? Not the power one but a small reset button
- mlapMay 26, 2021InitiateI never used the app.
But holding the little reset button for a second of 20 in, wil do a factor reset.
Be sure you know the default logging 😉
