Dracarus
May 26, 2021Initiate
Router R7000 keeps going offline
Router keeps going offline up to 4 times a day and it’s only 1 year old. I have updated the firmware, done multiple reboots to both router and modem. Any support out there or solutions that have worke...
Dracarus
In my app I don’t see an option to do a factory reset. Are you referring to the reset button on the back? Not the power one but a small reset button
mlap
I never used the app.
But holding the little reset button for a second of 20 in, wil do a factor reset.
Be sure you know the default logging 😉
