MariusMarcoci
Mar 22, 2023Aspirant
Router R7800 freezes time to time
Hi I have my R7800 for several years but from time to time (sometimes several times a day) the router freezes, and no connect is possbile any longer via cable or wifi the only way the get my router...
MariusMarcoci
before the router i have a huawei for fiber in the bridge, i tried without the bridge and the same thing happens it's not from huawei .. because i can't access the router netgear when it's blocked
michaelkenward
Mar 22, 2023Guru - Experienced User
Unfortunately, on top of the strange formatting, that doesn't take us much further in understanding the technology that feeds your R7800.
What does "a huawei for fiber in the bridge" mean?
Huawei what? What "bridge"?
- MariusMarcociMar 22, 2023Aspirant
sorry i checked now and it is ZTE Gpon ONT model ZXHN F618 befor router R7800
- michaelkenwardMar 22, 2023Guru - Experienced User
If this is a simple ONT, with no router features, you should be able to,plug the R7800 into that. Anything else in there could get in the way.
It is ONT with router but is disable and is bridge, it's just fiber converter now
and the r7800 use pppOE conection
