MariusMarcoci
Mar 22, 2023Aspirant
Router R7800 freezes time to time
Hi I have my R7800 for several years but from time to time (sometimes several times a day) the router freezes, and no connect is possbile any longer via cable or wifi the only way the get my router...
Kitsap
Mar 22, 2023Master
MariusMarcoci wrote:Hi
the only way the get my router run ist to turn it off and on again
I tried every official version, even from Voxel and they all do the same
does someone else knows of similar problems ? does someone have a solution ?
Marius
Recommend your check the power converter you are using for your R7800. Look at the back of the R7800 and there will be input voltage and current requirements. Check the transformer portion of your power converter and it will show output voltage and current specifications. Do the two compare favorably? The voltage needs to be a direct match. The power converter output current has to be at least as much as the R7800 requires for input.
There is also a chance your power converter is starting to go bad. How old is your R7800?
Do you operate the R7800 in a warm climate? Maybe it is getting over heated.
MariusMarcoci
I have it for 4 years, I have now changed his power supply with another one and am checking for a few days
