Faccin0
Feb 12, 2023Guide
Router R7800 issue with dns0.eu IP address
Hello, I've tried to use the new DNS provider dns0.eu (192.110.81.0) with my router R7800 but the IP of the provided is "invalid" because the IP ends with .0. Tried with the same provider but with a...
microchip8
Feb 12, 2023Master
if the firmware is not compatible with this and says it's an invalid address, I don't think you can work it around. Firmware needs to be updated or you can install Voxel's firmware and try on there; it's basically stock firmware with improvements, fixes and a bit more functionality.
- KitsapFeb 12, 2023Master
The link to Voxel's website is here: http://www.voxel-firmware.com/Downloads/Voxel/html/index.html
Before your jump in, carefully review the README file at the top of the page.
- Faccin0Feb 12, 2023GuideIs there a way to engage the team into this issue and have an official fix.
The router must be stable and secure and I'm not so much into flashing the firmware with one that's not official- michaelkenwardFeb 13, 2023Guru - Experienced User
Faccin0 wrote:
Is there a way to engage the team into this issue and have an official fix.You should know that this community is essentially a user-to-user venue to talk about technical issues, with some input from a small band of Netgear techies.
Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
- Faccin0Feb 13, 2023GuideNo way to contact the support without paying a fee. That's very nice...
