Faccin0
Feb 12, 2023Guide
Router R7800 issue with dns0.eu IP address
Hello, I've tried to use the new DNS provider dns0.eu (192.110.81.0) with my router R7800 but the IP of the provided is "invalid" because the IP ends with .0. Tried with the same provider but with a...
microchip8
Feb 12, 2023Master
if the firmware is not compatible with this and says it's an invalid address, I don't think you can work it around. Firmware needs to be updated or you can install Voxel's firmware and try on there; it's basically stock firmware with improvements, fixes and a bit more functionality.
Kitsap
Feb 12, 2023Master
The link to Voxel's website is here: http://www.voxel-firmware.com/Downloads/Voxel/html/index.html
Before your jump in, carefully review the README file at the top of the page.
