CTMax's avatar
CTMax
Router R7900P firmware upgrade not available - Attention Netgear!
Received email from Netgear security, to upgrade router firmware to V1.4.1.62. (current version 1.4.1.50_1.3.10). App message no upgrade available. Browser method no luck. It's been a month now.   ...
  • plemans's avatar
    Sep 04, 2020
    You can manually update. I'd highly recommend doing it over the app or wireless. Wireless or the app has been where we see the most issues with corrupt firmware. So if you can do it over a hardwired connection, you'll have the best results.
    https://www.netgear.com/support/product/R7900P.aspx#download
