CTMax
Sep 03, 2020Aspirant
Router R7900P firmware upgrade not available - Attention Netgear!
Received email from Netgear security, to upgrade router firmware to V1.4.1.62. (current version 1.4.1.50_1.3.10). App message no upgrade available. Browser method no luck. It's been a month now. ...
- Sep 04, 2020
You can manually update. I'd highly recommend doing it over the app or wireless. Wireless or the app has been where we see the most issues with corrupt firmware. So if you can do it over a hardwired connection, you'll have the best results.
https://www.netgear.com/support/product/R7900P.aspx#download
michaelkenward
Sep 06, 2020Guru - Experienced User
CTMax
Sep 14, 2020Aspirant
Thanks both of you for your help.
Seems both answers together provide solution, plemans includes link to manual update instructions and michaelkenward’s included link to firmware.
CTMax
