bstreyle
Mar 27, 2022Follower
Router r900 factor reset not accepting "password" as the default password
I received the above router from my son since he got a new one to replace an older router. I did a factory reset as described in the instructions, bur when I put password in the field it states that...
Kitsap
Mar 27, 2022Master
Make sure you are using all lower case letters.
Clear the cache on the web browser you are using.
Try another web browser.
