bstreyle
Mar 27, 2022Follower
Router r900 factor reset not accepting "password" as the default password
I received the above router from my son since he got a new one to replace an older router. I did a factory reset as described in the instructions, bur when I put password in the field it states that...
Mar 28, 2022Guru - Experienced User
when you reset, are you pushing and holding reset while its powered on until the lights change?
I've seen it just clicked on thinking that resets it.
