IvorJohn
Dec 23, 2020Follower
Router recycling
Does anyone know of any ways to reuse or repurpose a functioning netgear router? Thanks!
michaelkenward
Dec 24, 2020Guru - Experienced User
The C7000 listed in your footer is a cable modem/router. This means that, unlike most DSL modem/routers, it is not easily reused as an wireless access point or as a standalone router, unlike. You may be able to do it, but the device doesn't come with simple instructions in the manual.
The first thing to do is this:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
wcalifas
Dec 24, 2020Prodigy
you could use it as an access point, I used my old netgear dsl/router as an access point. Mine is a little older so don't know if converting it to an access point is different than mine. Of course you need to disable the dhcp part of it.
- tomasz_ngDec 24, 2020Guide
You can also just give it away to someone who needs one. No need to clutter your home. I use Freegle to advertise when I have something to give away for free, and there's almost always someone who does within a day or two.
- michaelkenwardDec 24, 2020Guru - Experienced User
DSL modem/routers are designed for that, with instructions in the manuals Use the Modem Router as a WiFi Access Point.
Cable modem/routers don't have that advantage. You have to resort to a different approach.
- antinodeDec 24, 2020Guru
> netgear router? [...]As what?
> Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Is that the model?
> [...] You have to resort to a different approach.https://community.netgear.com/t5/x/x/m-p/2025635
I'm sure that he's aware of that method. Why he didn't refer you to
it is unclear.
