Derekowumi
Apr 11, 2021Tutor
Router seems to be stuck in boot loop
I got home and tried to connect to the network and the network wasn’t there just for me to go to the router and it seems to be stuck trying to boot up any help?
- Apr 11, 2021
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Apr 11, 2021Guru - Experienced User
Seems to be stuck in a boot loop...
What's actually happening?
What are the led's doing?
What have you tried to fix it?
have you tried pushing and holding reset for up to 30 seconds while its powered on?
- DerekowumiApr 11, 2021Tutor
The led is solid amber
have held the reset button for 30/30/30 no avaIl
i tried tftp couldn't manage to ping the router.
- plemansApr 11, 2021Guru - Experienced User
- DerekowumiApr 12, 2021Tutor
I am on linux, i managed to be able to ping my router but the nmp thing isn't working i'll try the tftp
