pault963
Dec 28, 2018Tutor
Router speed
My internet speed through Spectrum is 100 Mbps. I have a brand new modem from Spectrum. My wifi router is a R7000P Nighthawk AC2300. My question is when I plug the Cat6 cable directly into the modem,...
- Dec 29, 2018
Reset the router to factory settings. Rebooted everything and speeds are running 117Mbps plus.
Thanks for all the help. Paul..............
shadowsports
Dec 28, 2018Hero
Greetings,
R7000P.
What FW version are you running?
Is this the shipping FW or was it upgraded? If it was upgraded, how was it done, manually or automatically?
Do you have QoS, Traffic Meter or Smart Connect enabled?
Please provide answers to the above questions, then reset the router to default settings and retest speed.
antinode
Dec 28, 2018Guru
> [...] I have a brand new modem from Spectrum. [...]
Not a very detailed description of anything. Does it have a maker
and model number?
> [...] when I plug the Cat6 cable directly into the modem, [...]
What's at the other end of "the Cat6 cable"?
- pault963Jan 01, 2019Tutor
Just funny how others solved my problem with the information that I supplied and you needed more information and had no answers. Sorry you had no solutions. Well thanks anyway.
- antinodeJan 01, 2019Guru
> supplied and you needed more information and had no answers. [...]
Assuming that that was addressed to me, ...
When your answer to every question is to reset the settings, then
very little information is needed. I forget -- Was I the only one who
asked you questions?
Does "the information that I supplied" include "your PM's"? I might
not have read all of those.
> [...] Sorry you had no solutions. Well thanks anyway.
I'm sorry that your problem report contained so little useful
information, and that some basic questions were too difficult for you to
answer.
