pault963's avatar
Dec 28, 2018
Router speed
My internet speed through Spectrum is 100 Mbps. I have a brand new modem from Spectrum. My wifi router is a R7000P Nighthawk AC2300. My question is when I plug the Cat6 cable directly into the modem,...
  • pault963's avatar
    pault963
    Dec 29, 2018
    Reset the router to factory settings. Rebooted everything and speeds are running 117Mbps plus.
    Thanks for all the help.  Paul..............
