crashnburn441
Mar 02, 2020Tutor
Router throttling speeds?
I have both a Nighthawk modem and Router(R6700v3). ISP internet is 600-700mbps. When i hardwire my laptop directly into the modem, I get these speeds. however, anything plugged into the router itself...
- Apr 12, 2020Roll the firmware back to 3_66. Looking through all the things I can find... isn’t much and NETGEAR support just hangs up on you. Useless pieces of **bleep**. Yes I work support, and yes I work in tech. The firmware after their Armor release seems to throttle at 250. Don’t know if it is the armor or what, but every update after that throttles at 250 even on a FIOS connection. Don’t waste time or money on their support as they don’t know nor want to help.
michaelkenward
Mar 03, 2020Guru - Experienced User
Model number?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
- crashnburn441Mar 03, 2020Tutor
Nighthawk Router Firmware version is V1.0.4.84
Modem is NETGEAR Nighthawk Cable Modem with Voice - CM1150V - dont know how to check firmware version on that, however as I said hard-wiring other devices into that directly achieves speeds that I am supposed to get.
- michaelkenwardMar 03, 2020Guru - Experienced User
OK. Not a modem/router. Forget about its firmware. It is beyond your control.
Check that you do not have QoS enabled on the R6700. Traffic metering, parental controls and other stuff that puts a strain on the R6700's processor can also cause slowdowns.
I haven't seen a flood of reports of issues with that version, but you could try going back a version or two to see if it helps.
When you try different versions, it can help to do a factory reset with the new firmware.
- crashnburn441Mar 04, 2020TutorFactory reset and rolled back router to version I opened out of the box... V1.0.4.82_10.0.57 - same results. Still getting around 250mbps wired in.
All QoS settings are unchecked and most settings are defaulted from reset.
