crashnburn441
Mar 02, 2020Tutor
Router throttling speeds?
I have both a Nighthawk modem and Router(R6700v3). ISP internet is 600-700mbps. When i hardwire my laptop directly into the modem, I get these speeds. however, anything plugged into the router itself...
- Apr 12, 2020Roll the firmware back to 3_66. Looking through all the things I can find... isn’t much and NETGEAR support just hangs up on you. Useless pieces of **bleep**. Yes I work support, and yes I work in tech. The firmware after their Armor release seems to throttle at 250. Don’t know if it is the armor or what, but every update after that throttles at 250 even on a FIOS connection. Don’t waste time or money on their support as they don’t know nor want to help.
michaelkenward
Mar 03, 2020Guru - Experienced User
Model number?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
crashnburn441
Mar 03, 2020Tutor
Nighthawk Router Firmware version is V1.0.4.84
Modem is NETGEAR Nighthawk Cable Modem with Voice - CM1150V - dont know how to check firmware version on that, however as I said hard-wiring other devices into that directly achieves speeds that I am supposed to get.
