lychaeus
Mar 11, 2021Tutor
Router Throttling Speeds
Hey everyone, I have a Nighthawk R8000 and gigabit internet service (1gb up/down). With a direct connection to my Macbook via my modem, I get 920 up/down. With a direct connection to my Macb...
Mar 11, 2021Guru - Experienced User
What modem is it connected to?
After the firmware changes, did you factory reset?
- lychaeusMar 11, 2021TutorIt’s a Nokia modem. As far as the exact model, I’m unsure — it was provided by the ISP.
I was able to downgrade only to 1.0.4.12 — anything before that is apparently incompatible with the router. The speeds are now sitting at around 430/550. Still not good enough, but better than nothing.- plemansMar 15, 2021Guru - Experienced User
What nokia is it?
