Ian57
Jun 15, 2021Follower
Router to Router
I am looking to run 2 M60 routers with 3 satelites. I need a router on the other side of the house from my modem. Here is what i want to do if possible: Arris Modem (no router, just modem) d...
michaelkenward
Jun 16, 2021Guru - Experienced User
Start with your problem rather than trying to troubleshoot your idea of what the solution might be.
What do you want the second router to do?
If you just want to get the Internet on the other side of the house you don't need a second router. If you can't just run a cable, you can use something like a wifi extender or a powerline network over your mains circuit.
