theredranger8
May 25, 2017Aspirant
"Router Update" option missing along with most of the GUI
I just set up my R7000 Netgear router today. It seems to be working great as far as our internet speed and nework signal range go, but when I log in to access the router's GUI, almost all of it is mi...
- May 26, 2017
Have you tried to bypass genie and use a browser and log in the router via 192.168.1.1?
William10a
May 26, 2017Master
- theredranger8May 26, 2017Aspirant
Yes. The genie is not my problem. It's the router itself at 192.168.100.1 that is missing all of those important options.
I bought this router over eBay. It is used, but very well-kept. (It literally had everything original in pristine condition, including the plastic wrap). The original owner said he's installed the fix for the security vulnerability, and that he did a factory reset just before seling it. He was a little shocked to see those pictures. (For the record, I do trust this person.)
He recommended trying the reste button on the back of the router. I'll be home later today and will be trying that.
I just realized that I misunderstood your question. I thought by "genie", you were referring to the mobile app (which works fine, even where the browser genie fails.) I'll try 192.168.1.1 tonight as well.
