theredranger8
May 25, 2017Aspirant
"Router Update" option missing along with most of the GUI
I just set up my R7000 Netgear router today. It seems to be working great as far as our internet speed and nework signal range go, but when I log in to access the router's GUI, almost all of it is mi...
- May 26, 2017
Have you tried to bypass genie and use a browser and log in the router via 192.168.1.1?
William10a
May 26, 2017Master
theredranger8
May 26, 2017Aspirant
Yes. The genie is not my problem. It's the router itself at 192.168.100.1 that is missing all of those important options.
I bought this router over eBay. It is used, but very well-kept. (It literally had everything original in pristine condition, including the plastic wrap). The original owner said he's installed the fix for the security vulnerability, and that he did a factory reset just before seling it. He was a little shocked to see those pictures. (For the record, I do trust this person.)
He recommended trying the reste button on the back of the router. I'll be home later today and will be trying that.
