Ackis01
Apr 10, 2019Aspirant
Router VPN giving IP outside subnet, how can I change that?
Hello - decided to try playing around with the OpenVPN functionality of my router to take advantage of my Pi-Hole. I'm able to connect and I get an IP address, however it looks like the IP I'm getti...
- Apr 11, 2019
Nothing.
schumaku
Apr 11, 2019Guru - Experienced User
The OpenVPN server configuration includes the VPN address scope to be used. While these consumer devices allow to disable the DHCP, there is no UI control to change the OpenVPN client IP range.
Ackis01
Apr 11, 2019Aspirant
So nothing I can do?
- JoseAndres041Apr 11, 2019Luminary
Nothing.
- Ackis01Apr 11, 2019Aspirant
Thanks for the response. Just another disappointment with this crap router.
- michaelkenwardApr 12, 2019Guru - Experienced User
New firmware on at least one Netgear device killed off the ability to use Pi-Hole. Rolling back fixed the problem.
