Ackis01
Apr 11, 2019Aspirant
Router VPN giving IP outside subnet, how can I change that?
Hello - decided to try playing around with the OpenVPN functionality of my router to take advantage of my Pi-Hole. I'm able to connect and I get an IP address, however it looks like the IP I'm getti...
- Apr 11, 2019
Nothing.
Ackis01
Thanks for the response. Just another disappointment with this crap router.
michaelkenward
Apr 12, 2019Guru - Experienced User
New firmware on at least one Netgear device killed off the ability to use Pi-Hole. Rolling back fixed the problem.
