helixhaze12g
Jan 13, 2019Aspirant
Router Web Page refuses to connect after updating settings
Hi,
I am using a Nighthawk D7000v2 as my main router.
When I change settings on the router via netgear genie (router web page), most of the time it will refuse to connect after updating.
The ...
- Jan 13, 2019
> [...] guess you didn't like my post.
Still not thrilled by it. (What's the actual error message from the
web browser?)
> Firmware version: V1.0.0.51_1.0.1
This must be some new meaning for "the latest". I see
"V1.0.0.53_1.0.2" on the server.
> >Latest firmare:
> When I checked if an update was available the router said I had the
> latest version
Relying on Netgear firmware to "Check for new version from the
Internet" is like relying on Netgear firmware for anything -- the result
is often disappointment.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
> > Reset router:
> I mean power cycle
That's not the common meaning of "reset" in this context.
for Documentation. Get the User Manual. Look for "reset". It's far
from a sure thing, but it's possible that a settings reset (and manual
reconfiguration) would help in this case. (Restoring saved settings
could restore old problems.)
> >Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router:
> This was the only one I could select in the forum but it is v2
Wrong forum. It's in the list at:
https://community.netgear.com/t5/x/bd-p/home-dsl-modems-routers
But yes, that firmware version agrees with "v2". (Netgear "Community"
forum organization and administration are on a level similar to its
router-firmware quality.)
> I posted here instead of a formal support request because I can't always
> reproduce the error and thought someone might have come across the same
> issue.
It's worth a try, but a reproducible error is always easier to fix,
and a bug which never gets formally reported may never get fixed.
> I will try and older firmware version
I'd start with the newer one, and than start working backward.
(And/or a settings reset.)
> Yes this is a minor issue, [...]
I disagree, but it would bother some users more than others.
(Especially those with remotely operated equipment.)
Netgear routers have some history of management web servers dying
with little or no provocation. I don't recall reading of any cases of
this on a D7000v2, but that proves nothing.
> [...] Maybe my expectation is too high for a consumer grade router.
I'd say not. My D7000[v1] (currently V1.0.1.70_1.0.1) is not
bug-free, but can't remember ever catching its web server dying.
Generally, if that happens, it's a bug.
antinode
Jan 13, 2019Guru
Firmware version?
Which settings, exactly? "most of the time" is not helpful. Does
some specific change always cause the problem? Does some other specific
change never cause the problem? Or does some specific change sometimes
cause the problem, and sometimes not?
What, exactly, does "it will refuse to connect" mean? What, exactly,
are you doing? Is there some actual error message which you get (from
your (unspecified) web browser?)?
> I have the latest firmware [...]
As always, an actual version number would be more useful than your
opinion of what's "the latest" today.
> [...] and I have reset the router many times, [...]
What, exactly, does "reset the router" mean to you? Power cycle?
Hold the Reset button down for several seconds? Other?
> Does anyone have a suggestion on how to fix this?
Submit a formal support request to Netgear? Try a different/older
firmware version?
Note that that suggests a D7000[v1], whose firmware is different from
that of a D7000v2. (One more reason for providing an actual firmware
version.)
> Is the issue that you update [...]
I assume that "change settings" and "update firmware" mean different
things. But, again, a detailed description of an actual action which
causes the problem might avoid this sort of confusion, too.
helixhaze12g
Hi antinode, guess you didn't like my post.
This has happened with a few different setting changes, this time it was changing DNS servers.
I would guess it happens when the router is updating settings and not rebooting.
I have tried on chrome, firefox and IE and the message
>Latest firmare:
When I checked if an update was available the router said I had the latest version
> Reset router:
I mean power cycle
> I assume that "change settings" and "update firmware" mean different things
yes, change settings for example, change DNS servers, VLANID, LAN IP, etc.
I posted here instead of a formal support request because I can't always reproduce the error and thought someone might have come across the same issue.
- antinodeJan 13, 2019Guru
web browser?)
> >Latest firmare:
> latest version
instructions.
> > Reset router:
> I mean power cycle
> issue.
Generally, if that happens, it's a bug.- helixhaze12gJan 15, 2019Aspirant
So I downloaded the firmware ( V1.0.0.53_1.0.2) from netgear site and it is working fine now.
So hopefully it will be ok.
Didn't realise that the router update check would not get the latest firmware.
I appreciate your replies, but I think since this is a community forum you should be more welcoming and friendly.
