helixhaze12g's avatar
helixhaze12g
Router Web Page refuses to connect after updating settings
Hi,  I am using a Nighthawk D7000v2 as my main router.  When I change settings on the router via netgear genie (router web page), most of the time it will refuse to connect after updating. The ...
  • antinode's avatar
    antinode
    Jan 13, 2019
    > [...] guess you didn't like my post.
       Still not thrilled by it.  (What's the actual error message from the
    web browser?)
    > Firmware version: V1.0.0.51_1.0.1
       This must be some new meaning for "the latest".  I see
    "V1.0.0.53_1.0.2" on the server.
    > >Latest firmare:
    > When I checked if an update was available the router said I had the
    > latest version
       Relying on Netgear firmware to "Check for new version from the
    Internet" is like relying on Netgear firmware for anything -- the result
    is often disappointment.
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.
    > > Reset router:
    > I mean power cycle
       That's not the common meaning of "reset" in this context.
    for Documentation.  Get the User Manual.  Look for "reset".  It's far
    from a sure thing, but it's possible that a settings reset (and manual
    reconfiguration) would help in this case.  (Restoring saved settings
    could restore old problems.)
    > >Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router:
    > This was the only one I could select in the forum but it is v2
       Wrong forum.  It's in the list at:
          https://community.netgear.com/t5/x/bd-p/home-dsl-modems-routers
    But yes, that firmware version agrees with "v2".  (Netgear "Community"
    forum organization and administration are on a level similar to its
    router-firmware quality.)
    > I posted here instead of a formal support request because I can't always
    > reproduce the error and thought someone might have come across the same
    > issue.
       It's worth a try, but a reproducible error is always easier to fix,
    and a bug which never gets formally reported may never get fixed.
    > I will try and older firmware version
       I'd start with the newer one, and than start working backward.
    (And/or a settings reset.)
    > Yes this is a minor issue, [...]
       I disagree, but it would bother some users more than others.
    (Especially those with remotely operated equipment.)
       Netgear routers have some history of management web servers dying
    with little or no provocation.  I don't recall reading of any cases of
    this on a D7000v2, but that proves nothing.
    > [...] Maybe my expectation is too high for a consumer grade router.
       I'd say not.  My D7000[v1] (currently V1.0.1.70_1.0.1) is not
    bug-free, but can't remember ever catching its web server dying.
    Generally, if that happens, it's a bug.
