bladeinsheffiel
Sep 03, 2023Aspirant
Router wifi network stopped working Nighthawk X6 AC3200 Smart WiFi Router (R8000)
 Hi,      My Router has stopped working, the indicator lights cycle through but the wifi doesn't work - not sure what has caused it. Any suggestions for ways to diagnose of fix the fault most welcome....
bladeinsheffiel
Sep 11, 2023Aspirant
Thanks! I'll try that and let you know how it goes
Sep 16, 2023Guru - Experienced User
- bladeinsheffielSep 16, 2023Aspirant
Hi,
No success with the 30-30-30 reset.
I tried reinstalling the firmware as per the advice on the Netgear site, however that didn't work - there was never a point at which the power light was flashing - I tried the upload just after restarting, but it wouldn't install.
I do plan to try it again, maybe I'll have better luck next time
Thanks for all the help.
- FURRYe38Sep 16, 2023Guru - Experienced User
Try nmrpflash:
https://github.com/jclehner/nmrpflashIf all this fails, then the router maybe busted.
Good Luck.
Thanks! Will have a crack.
đ€
