Iww5000m
Dec 27, 2024Aspirant
Router won’t allow connection to google nest doorbell
I have a Nighthawk R6400. I cannot get a Google Nest Doorbell to communicate and send video through my router. I previously had the same model of doorbell working properly. When it broke and I install...
Dec 27, 2024Guru - Experienced User
What modem is the router connected to?
Did you contact google?
If its connected to the router, I'd contact google. Maybe something needs to be changed with the account
- Iww5000mDec 28, 2024AspirantIt’s an Adtran fiber optic modem. I’ve got great upload and download speeds on all the devices and no issues with any other device, even the other non-doorbell google cams. I went through every option with google, and it works as it should on a hotspot. Are there any settings on the router that would allow it to connect but not allow it to let the video through?
- plemansDec 30, 2024Guru - Experienced User
what adtran is it?
