imattcampbell
Feb 01, 2021Follower
Router won't communicate over wire or wireless after firmware update.
After firmware update, router power light flashes orange and won't communicate over wire or wireless. The router is unresponsive to factory reset. Warranty is long passed. What next steps do I take?
microchip8
Feb 01, 2021Master
You have a bricked router. TFTP recovery https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Feb 01, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
