travis14
Mar 18, 2021Aspirant
router won't connect to internet unless I connect computer to LAN
Router Firmware: V1.0.0.48 Modem: Spectrum Business - Technicolor ET2251 OS: macOS / IOS This is at my office and I can't access modem since its locked in a closet somewhere but when I arrive i...
Mar 18, 2021Guru - Experienced User
what modem is in that closet?
Who manages it?
Is there another router on the network or connected to that modem?
travis14
this is specturm's modem (Technicolor ET2251) and they manage it. my office is in a building with other businesses so the closet probably has multiple modems in there, but its a simple modem with coax and ethernet port so nothing else should be connected to the modem itself. I'm not sure how they manage the network.
- plemansMar 18, 2021Guru - Experienced User
I'm more curious if its a shared connection. As it in goes modem--->router---->your office.
So if they have something else connected to the modem
- travis14Mar 18, 2021Aspirant
I'm not sure. I don't think my setup is anything unusual. I'm relatively new to the building but I can't imagine other offices living with this problem. In fact, I would assume other offices may have only wireless connections to their router/modem setup. I just don't know why everything works fine if I have just one device connected to LAN. If its not an easy config setting or something, I may just try a different router.
I'm trying to figure out if you have a double nat that could be causing your issue.
https://kb.netgear.com/30186/What-is-Double-NAT
If they have a modem + router setup, when you attach yours it could be causing issues.
